I'm very familiar with Eagles, having owned every body style except for the Kammback (think an AWD AMC Gremlin...)
Anyway, they are good stout cars, I used to four-wheel in one back in high school. Oddly enough, I never managed to get my '82 wagon stuck, though I did come close.
They originally included skidplates on the front and over the transfer case.
All AMC Eagles are All-Wheel-Drive. From '80-81 they used the NP-119 case (single-speed, always in 4WD, center viscous coupling), from '82 to '85 and '87 to '88 they used the NP-129 case (single speed, vacuum selected 2/4WD, center viscous coupling). In '86 they used the NP-128 case (single speed, vacuum selected 2/4WD, center open differential). For this reason, '86's don't work quite as well as the others.
Numerous transfer cases are interchangeable to give low-range in an Eagle, check out this URL:
Swap your Eagle's Transfer Case
From '82 to '84 they used a right half-shaft axle disconnect on the front, requiring you to stop to shift to and from 4WD. In '85 they eliminated this disconnect, allowing shift-on-the-fly. Do NOT attempt shift on the fly in an '82 to '84 Eagle, the front axle would likely explode!
Independent front suspension with equal length CV shafts (they are interchangable left/right), dana 30 front axle. AMC 20 rear axle, with the
tapered axle / hub assembly, just like CJ's of the era. Lockers are available for these axles.
Frame horns are different between the 4 and 6 cylinder Eagles. The nose of the front differential is located by a bracket bolted to the engine block, and the front diff hangs from the engine mounts. To swap in a different engine, you have to build a crossmember to locate the front axle. The 4.0 liter I6, at least through 2000, had the necessary mounting point on the block for the Eagle front axle, so you can swap a complete 4.0 I6 into one(I haven't looked to see if it's on the 4.0 liter in my Rubicon or not). Here's a link to the article on a V8 swap:
Flying with V8 Eagles
I have an '82 Eagle SX/4 Sport in my garage I've been working on. 258 and a T5 5-speed... should be a fun little car once I find the time to finish it.
More info:
EagleWeb
