Re: BTT Anyone???
The big Leece-Neville will come in three flavors.
The 105 Amp
The 130 Amp
The 160 Amp.
Although the tags will sometimes read screwy, like 102, 109 or 135...
The OEM user just though that sounded cooler than the standard 105, 130, 160...
Leece-Neville only released rectifier bridges in 105, 130 & 160, so regardless of what the tag reads, you have one of the three.
Look for voltage! You are looking for a 12 volt alternator.
For obvious reasons, if you acquire a 24, 36 or 48 volt alternator, throwing 12 volts at the rotor isn't going to get you anywhere.
Most large trucks use 12 volt charging systems now, so 12 volt units are a lot more common than they were 20 years ago...
Don't walk past a 24 volt Leece-Neville if you can find one for cheap.
Most of the case parts, brush/ regulator holders will interchange, PULLEYS will interchange, and the rectifier bridges will interchange.
It would be a very good parts source, and those brush holders and pulleys are hard to find, and expensive when you do...
For obvious reasons, the 160 amp is the one to have, but the 105 welds everything I've tried it on so far, depending on the size of the rods...
The smaller the rod diameter, the better you will do with limited amperage. (Thanks CJ Dave!)
The verbile resistor is for controlling the current you throw at the Rotor, and that in turn controls the output.
You get the unit about where you want it doing test beads and adjusting with engine RPM, and you can use the resistor to 'Find Tune' your weld...
The resistor works well, I got mine from NAPA for about $12.
Ask for a generic heater motor control, and make sure the knob moves smoothly, and doesn't have 'Notches'.
If it has 'Notches', reject it. You can get that close with engine RPM adjustments...
With the resistor, if you watch the voltage output, you can actually quick charge a battery in a pinch, and just for giggles and grins, I've excited mine with flashlight batteries to charge a battery...
(Test bench battery dead, and charger outside on the lawn mower.
'D' cell mag light handy, so I thought, "What the he11?.."...... It worked!)
Used the verbile resistor to control output, and used the welding clamps to charge the bench battery....
'D' cells don't last long, but if you were REALLY in a pinch, this is another option...
EXERCISE CAUTION AROUND THIS DEVICE!
This alternating generator is capable of putting out 130 volts at over 160 amps,
And IT CAN KILL YOU!
