Did ANY Dana 60 REAR Full Floating rear ends come from the factory with 1.5" diameter shafts and 35 splines. Or, where all Dana 60 Full Floaters and Semi Floaters 1.31" diam. 30 spline shafts? I was under the impression that most rear full floating 60s were 1.5" diam. 35 spline, but it's been brought up on the Jeep page that this isn't the case and that most front 60s have the smaller axles as did most rear ends. Any help clearing this up would be appreciated as I am trying to swap one into the rear of my truck and want a full floater with the bigger axles. Is it possible that 60s with the bigger drums (like out of a 1 ton truck) would have the bigger axles? Just a thought.
I also have probably a really dumb question. Say I can find a FF rear Dana 60 with the 1.5" diam. 35 spline shafts and the huge drums. Would it be possible to redrill the drum to run a 6 lug setup (using a mill to keep the hole concentric) and then install the master cylinder and the brake booster from a 1 Ton to make the huge drums work? Again, any input is appreciated. Thanks for your time,
Sean
Sean
