My thoughts:
Do throttle position sensors (TPS) wear out? That is the other part on the TB. It electrically measures the position of the throttle plates (via voltage) so that the computer knows what rpm the engine is running at so it can compensate for timimg, emissions, and everything else it monitors. I forget whether or not this is actually open in the TB or not. If it is, maybe some carbon got on it when you were cleaing the TB. Or maybe, this part is not bad but just getting "lazy" from age and wear.
I think there will always be some sort of hesitation as the computer (brain) must "see" the position of the throttle and then compensate for that with increased timing and everything else. Kinda like touching something hot; a signal is sent to the brain, the brain analysis this information, then sends a response to the hand to let go. If this was immediate, we would never get a burn or blister.
I forget what the MAP (manifold absolute pressure) sensor controls but that may be something to look into. I'm not sure where yours is mounted (usually on the firewall) but it has a vaccum line going to it.
At my local Pep Boys, they have a diagram of all the components that make up the fuel injection system. The diagram shows stuff like "if you have this problem, this is the part to look at". Good luck!
Imagine life with no paved roadways!
Billy
