Kasea 90 Oil injection - Off-Road Forums & Discussion Groups
Youth ATV For discussion of all youth ATV's 125cc and smaller.
post #1 of (permalink) Old 06-23-2003, 09:26 PM
When you remove the oil injection, is there any aftermarket plugs made so you can remove the entire part and also seal off that portion of the engine? (Sano parts...no broom sticks)
post #2 of (permalink) Old 06-24-2003, 08:52 AM
tony1034
Re: Kasea 90 Oil injection
When I removed the oil injection off my son's mini Kasea 50, I just left the oil pump there. I removed the hose to the carb and soldered the brass nipple closed. I also removed the plastic oil tank and hose going to the pump too. If you want to get rid of the oil pump and plug the hole, Greg Peak of Peak PowerSports, makes a plug for it. Check out:
http://dirtrides.com
He has everything to make that Kasea fly! I'm going to be handing the mini down to my daughter (about to be 3) and get my son (turning 6) a SkyHawk 90. The first thing I'm doing to it, before he even rides it are:
1. Remove oil injection (plug hole w/ Greg's piece)
Also swap out throttle cable for single cable. I just removed the second cable at the splitter to the pump on the mini, and plugged the hole in the splitter.
2. Remove carb restrictor.
3. Replace airbox with K&N or Uni.
4. Re-jet carb.
5. Replace stock wheels/rims with offset alum rims and SnowHog Tires. Possibly add small spacers too.
6. Slap on a set of Peak PowerSports custom nerf bars (they have a loop on the rear to protect the foot from the rear tire).
7. Upgrade suspension with Peak PowerSports +2 A-arms and works f/r shocks (+3 arms with Elkas are nice, but $$$).
Best regards,
Tony P.
