02 Lt50 - Off-Road Forums & Discussion Groups
Youth ATV For discussion of all youth ATV's 125cc and smaller.
post #1 of (permalink) Old 10-03-2002, 07:50 PM Thread Starter
02 Lt50
I have removed the exhust and intake restricters, But I haven't been able to find the carb silde sleeve. Also what plug would you recommend? Iam going to order a K&N tomorrow.
Any help would be greatly appriciated
weirdbeard55 is offline
post #2 of (permalink) Old 10-03-2002, 08:55 PM
Re: 02 Lt50
The restrictor in the carb prevents the slide from completely opening. Remove the air cleaner and check full throttle operation. If the slide clears the throttle bore someone already removed that restriction. If not, simply remove the two screws on the top of the carb, pull the slide spring back and release the throttle cable. Remove the 1/4" long sleeve located between the slide and carb top. Put it back together. Remove the float bowl and pull the small pilot jet (there are two -- leave the second one in).
