SCRAMBLER 50 CHEAP MODS - Page 3 - Off-Road Forums & Discussion Groups
Youth ATV For discussion of all youth ATV's 125cc and smaller.
post #21 of (permalink) Old 09-05-2002, 12:13 PM
Re: SCRAMBLER 50 CHEAP MODS
TWL,
Get rid of that spark plug!!!!! It is too hot!!! Go with a B8HS or a B8HV or a B8HVX or a B8HG
post #22 of (permalink) Old 09-06-2002, 05:26 PM
I know, thats what I thought too. I've had it in there about 2 weeks. I keep checking it and it's always toast brown. Is it still okay to use? Seems to run fine.
post #23 of (permalink) Old 09-07-2002, 10:38 AM
The stock plug is a BP7HS. I never use that plug for ANY purpose. You see, the "P" stands for a protruding electrode. That type of plug is intended for other applications -- where the insulator cannot, under normal conditions stay clean. In your case, I would at least go up to a B7HS (cooler than the 6). Your 6 plug may be brown now but it probably goes white under high load conditions. Save yourself the heart ache of a burned piston or worse and install a cooler plug.
post #24 of (permalink) Old 09-07-2002, 06:59 PM
Thanks for the advise.
I will change that plug tomorrow.
post #25 of (permalink) Old 01-22-2003, 02:38 PM
I've read the things that you've posted and you seem very informed on the atv. I was wondering if the things that you are discussing relate to the 2003 Scrambler 50 also? If so what is a quick and cheap modification to the atv? If the exaust restrictor is something that can be removed, where is it located and how is it removed?
post #26 of (permalink) Old 01-23-2003, 08:58 AM
It is located between head pipe and the cylinder. Remove your pipe and then remove the restrictor in the head pipe. It looks like a washer.
post #27 of (permalink) Old 01-23-2003, 12:22 PM
I attempted to do that a few days ago and there was no washer at all. The pipe was bolted directly to the head w/o out even a washer? Is this a change for '03?
post #28 of (permalink) Old 01-23-2003, 06:15 PM
Sounds like the restrictor has already been removed.
post #29 of (permalink) Old 02-24-2003, 05:48 PM
my son also has a sranbler 50. Both he and I are frustrated by the cdi speed limiter. Can someone please tell me in no uncertain terms how to disable it. As far as i can see it is a sealed unit.(do I just simply cut the green wire everbody eludes to)
Thankyou for any assistance you may offer
Rick <font color="blue"> </font color> <font color="red"> </font color>
post #30 of (permalink) Old 02-25-2003, 09:53 AM
The green wire is on the new Eton's. On the Polaris go to a 2000 or 2001 model cdi unit or replace it with a hi performance after market unit.
