husky50 vs t-rex50 vs xtreme50 - Off-Road Forums & Discussion Groups
Youth ATV For discussion of all youth ATV's 125cc and smaller.
post #1 of (permalink) Old 05-24-2002, 07:47 PM
Does anyone have any first hand knowledge on these quads: husky50 vs t-rex50 vs xtreme50?
Have heard that the company that sells husky has gone out of business. I guess getting parts would be a problem.
post #2 of (permalink) Old 05-25-2002, 09:29 AM
Re: husky50 vs t-rex50 vs xtreme50
The Huskey was a 4 stroke (something the majority of the buying public does not want in a youth mini).
Kasea is the best looking and best performing youth atv on the market. Currently 50 and 90cc atvís s are marketed by Suzuki, Eton, Polairs, Blazer (Jehm -- NOT Kasea), Aeon (Alpha Sports), Sundiro, T-Rex (Dinli), Jehm, Kasea, Bombardier (Jehm), Husky, XtremeMachine, Artic Cat, Yerf Dog, Manco, Dinli Helix (has an untested reverse feature), LEM and other manufacturers. Of the many atv manufacturers, Kasea (SMC)offers features that go beyond the ďother guys.Ē Virtually all of the youth atvís are equipped with fully automatic CVT transmissions (except the Suzuki 50 and LEM 50) and a 2 stroke oil injected engine, the features that make Kasea superior to other youth atvís begin here:
Front suspension
The Kasea front suspension is much stronger than that Eton, Polairs, Aeon (Alpha Sports), Sundiro, T-Rex, Jehm, Bombardier, Husky, Blazer, Extreme Machine, Artic Cat, Yerf Dog, Manco, Dinli Helix, LEM and some other manufacturers. The Kasea uses a double clevis style knuckle holder rather than the more common single holder. We believe that only Suzuki LT80 uses the same strong design as Kasea on the front suspension a-arms.
Rear suspension
The Kasea has the strongest youth atv rear swing arm and axle design on the market. It is a copy of the trusted design used by Yamaha on their performance atvís since the early 1980ís. No other youth atv has this strong of a rear suspension Ė it is simply the best. Many of the other youth atvís donít even offer a true sport atv style rear axle. We have found most youth atvís have a rear axle that is a thin metal shaft covered with tubing. Not only is the tube covered design weaker, it allows water to easily enter the carrier bearing area. Other youth atvís such as the Suzuki LT-80, LT50 and one Eton atv model do not even use a traditional rear swing arm. The LT80 and the one Eton model made the engine and transmission serve as the rear swing arm. The Suzuki LT80 and Eton design causes handling problems and is very difficult to modify for increased performance. On the Polaris and a few other models, the rear swing arm, although slightly longer, is too weak to be considered adequate.
Shock absorbers
Kasea built their atvís with true rebound and compression dampening Showa shocks that also feature compression preload spring adjusters. The only other youth atv that we have found that has a similar rear shock is Bombardier. Not even Suzuki has a good rear shock. This is a very important safety feature that is often overlooked. When the Kasea is ridden over a large sudden bump, the rebound dampening helps prevent the atv from ďbuckingĒ forward as the shock returns to its normal height. Compression dampening helps keep the shock from "packing" down.
Braking system
Kasea offers a traditional rear foot brake in addition to the front hand brake. This will allow your young rider to learn the proper use of hand and foot controls so he/she will be ready to advance to a full size atv with a manual clutch without relearning their riding technique. Some models such as the Blazer and Bombardier use full size levers that are hard for little hands to properly grip. The Suzuki 50 models do not even offer front brakes!! We will point out that the T-Rex, Manco, Sundiro and Yerf Dog have a rear disc brake but we feel that the drum brake in the youth market is sufficient for even racing needs.
Optional lighting
We believe that only the Kasea is equipped with a 80+ watt lighting coil and is pre-wired for lighting from the factory. All you need to do is purchase the Kasea lighting set that is found as standard equipment on the Kasea 150 atv or simply mount your own lights to the existing wiring. The key switch uses a third position to turn on the lights. Kasea even pre wired for a rear safety light and lighting for your whip antenna. No other youth atv on the market has this much lighting capability. If you want to add lighting to the Suzuki LT80, you will need a special electrical stator and wiring at a substantial cost. LT80 lighting kits that run off the battery only will result in a dead battery and a long walk home. The Suzuki 50 models cannot accept lighting.
Starting
Kasea, like most other youth atvís, offers electric starting with a manual back up kick starter and a fully automatic choke. Kasea studied the other atvís and took the ease of starting one step further. They added an automatic fuel valve. When the engine starts, the fuel is automatically turned on. When the engine stops, the fuel is automatically shut off. In comparison, the Suzuki and LEM models have manual chokes and all other youth atvís have manual fuel valves. We also note that if you want to add a manual back up starter to the Suzuki, it is a pull rope recoil starter that will cost an additional $80. In the unlikely event that you ever need a replacement electric starter for the Kasea, it will cost about $50 and can be installed in 5 minutes. The Suzuki starter costs about $250 and will require 3 hours of labor to complete the installation. The Suzuki 50 models only have pull rope starters that are difficult at best for young riders to operate.
Rim sizes
Here, you can easily install replacement rims of your choice! The front hubs use the common 4/110 bolt pattern (Honda) and the rear uses the common 4/100 bolt pattern (Blaster).
General Parts
Since most of the youth atv engines are similar, finding parts is usually not a problem. If you need gaskets, air filters, batteries, spark plugs, chain, tires or some basic engine components, Eton, Polairs, Aeon (Alpha Sports), Sundiro, T-Rex, Jehm, Kasea, Bombardier, Husky, Blazer, Extreme Machine, Artic Cat, Yerf Dog, Manco, Dinli Helix, will interchange. The Blazer, T-Rex, Bombardier, Yerf Dog, Manico and Polaris have a longer drive belt and side case cover though.
General Notes
The Kasea is one of the few youth atvís that does not provide a full floor board for the youth riderís feet. We have studied this issue and believe that the floorboard design may not be as good as claimed. In the event that the riderís foot gets wet or the board gets wet or covered with debris, it becomes a slippery dangerous platform. Kasea uses foot pegs just like a traditional atv. To improve any youth atv, we suggest that a good nerf bar with foot pegs and narrow spaced nets be added. I offer nerf bar packages for most youth atv models.
Speed
Kasea voluntarily follows the maximum speed limit recommendations of the Consumer Products Safety Commission. You may find other brands of youth atvís offered for sale that are out of the box ďfasterĒ than the Kasea; however, those atvís most likely do not comply with the CPSC regulations. For a new rider, there is no need for the extra speed out of the box. When their skills improve, the Kasea is the one to build.
Performance
From an aftermarket standpoint, I have the performance modifications for your youth atv. As your child grows, so will his/her ability to control more power. Instead of placing your child on a larger atv that can be dangerous for a younger rider to properly control, modifying a youth atv will provide the challenge that your child desires. I have replacement large bore cylinders, ported cylinders, custom billet aluminum cylinder heads, special over range transmissions, custom exhaust systems, performance carburetors, performance reeds, lighting kits, ignition systems, extended swing arms, wider a-arms, shock absorber kits and various tire and rim options. A special 4130 alloy frame is also in the works!
post #3 of (permalink) Old 05-25-2002, 08:18 PM
Thanks for the Kasea info.. I liked the 4 stroke engine, since most 2 strokes seem like they're either on or off, the 2 speed tranny was another plus.
