E-ton 50 starting - Off-Road Forums & Discussion Groups
Youth ATV For discussion of all youth ATV's 125cc and smaller.
post #1 of (permalink) Old 04-26-2002, 11:37 AM
chobbs70
E-ton 50 starting
I have an E-ton 50 that won't start after it has warmed up? I have learned to check the reeds when this occurs, I have spark and fuel but the reeds are always stuck open? I have checked to make sure they are clean ,I have flipped them over, bought carbon fiber etc. I even bought a new reed cage thinking the stock one was warped but no luck.
post #2 of (permalink) Old 04-27-2002, 10:06 AM
Re: E-ton 50 starting
If the pipe and the porting don't match you will get a sonic return wave that will push hot gasses into the intake system. The evidence of this is a dark exhaust color in the transfer tunnels. I don't know if this is the problem, but it is the first thing that comes to mind. It also could be a timing issue. If the CDI box is bad, or the flywheel has slipped, or the timing plate has moved, or the coil is partially shorted, the extra advance, especially on a hot motor, could cause this damage.
