Wiring for Off Road Racing - Off-Road Forums & Discussion Groups
Tools and Fabrication Forum for discussing the latest tools or fabrication methods for the Off-Road vehicle owner.
post #1 of (permalink) Old 02-26-2006, 02:45 PM
colinbrooks
OK guys, who's the 'guru' for best practice for how to wire up an off road racer. I'm not talking state of the art 'military spec' stuff, cos I've only got a VW powered Off Road Rail that hopefully I should be racing this season. It's just I've got to rewire some of it and I've read conflicting information about whether or not soldering is good or not. One theory being that it's good 'electrically' but bad because it alters the physical structure of the wire and makes it prone to breakage from vibration. Failing that anybody know of any good books on the subject? Thanks.
post #2 of (permalink) Old 03-28-2006, 08:20 PM
Re: Wiring for Off Road Racing
i'm not an expert on wiring of any kind
but i think solder will hold up better
maybe not flexible but...
super strong
don't forget to put liquid electrical tape
and shrink tubing
doze is offline
post #3 of (permalink) Old 04-03-2006, 02:26 PM
OK thanks. Don't know about the liquid electrical tape....maybe that's something you've only got in the States. Certainly I've never heard of it over here in the UK. Definitely gone with the shrink tubing though.
post #4 of (permalink) Old 04-30-2006, 02:46 PM
Soldering is good.
post #5 of (permalink) Old 05-01-2006, 10:50 AM
12 volt guy .com Solder, shrink wrap and zip tie everything for solid connections. Waterproof is good for ignition and other key equipment.
4x4mike is offline
post #6 of (permalink) Old 06-22-2006, 04:24 PM
NO, NO, NO!
You will do best to go where it all began.
I use the single screw wire straps from Willy's Jeeps as the are flexible and strong and yes take a little longer then glue and tape, but stay put as well as removable.
Instead of useing a screw driver flat head or philips.
Het the same size for a 5/16 wrench or what ever metric wrench is close to that size.
Then the heads are easy to tighten and loosen with out stripping a later down the road screw top.
We all know that will require a bit of drilling and easy out to recover from.
You can also use existing holes and make new ones so that when you place the harness in it can be tight yet flexible.
The little sigle screw wire mounts are not expensive either.
I use them from WWII, Jeeps, as well as early CJ's and can byt them Repro almost anywhere too.
This is your best choice that won't make a mess and can be undone for things such as a CB radio or a Stereo mounting at anytime.
Take it from Nate and I who off road 7 days a week together and race and crawl on the circuit, this is the best choice to use.
Bleddyn and Nate Cynfyn
Team G503
Ford Racing
1962 Ford M151 Desert Racer
1979 AM General M151A2 Rock Crawler (M998 IFS and IRS)
1946 Willy's CJ2A Rock Crawler with Chevy V8 and 33'Tires
Hummerkiller is offline
