F@*&@#$ ford - Off-Road Forums & Discussion Groups
Tools and Fabrication Forum for discussing the latest tools or fabrication methods for the Off-Road vehicle owner.
post #1 of (permalink) Old 02-18-2006, 07:18 PM
notofu
[email protected]*&@#$ ford
I am Trying to install a 3 inch steering arm lift block into a 78 F-150 supercab. The steering arm has to be removed to add in the lift block. The steering arm does not want to come free, I'm looking for anyone that has done this before, or that knows someone that has, or anyone that has any usefull advice. Hope someone can help me before I blow my head off.post or email [email protected]
post #2 of (permalink) Old 03-19-2006, 11:20 AM
Re: [email protected]*&@#$ ford
I'm sure you've tried the BFH and heat? (Big Freakin' Hammer) A two arm puller has worked for me. try some wd40 from the top. If your replacing the arm, why not torch it off? Just be carefull not to get into the splines of the gearbox.
stumblefoot is offline
post #3 of (permalink) Old 05-18-2006, 10:22 PM
By steering arm do you mean pitman arm? I wouldnt run a block there, but get another pitman arm for the length you need.
GTRider245 is offline
post #4 of (permalink) Old 05-19-2006, 09:51 AM
It sounds like an operator lack of mechanical knowledge issue rather than a brand issue.
BigNorm is offline
post #5 of (permalink) Old 05-20-2006, 10:39 PM
X2
post #6 of (permalink) Old 07-04-2006, 05:54 PM
krabysniper's Avatar
Just my .02 on the subject as far as safety is concerned, NEVER USE HEAT OR HAMMERS ON ANY STEERING OR SUSSPENSION COMPONENTS it can cause failures that CAN cause loss of life. Use the PROPPER tools for any given susspension or steering component repairs or replacements. They do make the PROPPER tools for a reason.
I third the operator failure.
krabysniper is offline
post #7 of (permalink) Old 10-02-2006, 05:32 PM
jdonahue
Krabysniper's post is correct. That being said you can easily remove your pitman arm with the following method.
Place a 4lb hammer on one side of the pitman arm where the sector shaft runs through it as a backup. Strike the exact opposite side of the pitman with another 4lb hammer, making sure to align hammers between blows. It shouldn't take too many hits to free it up. This is a junkyard method!
post #8 of (permalink) Old 10-26-2006, 11:54 AM
Apprentice
BAJA619's Avatar
Try any autozone or pepboys style store for a pitman arm remover. They may rent them or have a tool useage program.
If you have to buy one, it might cost about $65 and would be totally worth it to have in your tool box.
BAJA619 is offline
