Cleaning Polished Aluminum Wheels? - Off-Road Forums & Discussion Groups
Tire Tips, What Works Best One of the most-talked-about subjects on our Boards; applies to all makes and models.
post #1 of (permalink) Old 06-28-2009, 09:39 PM Thread Starter
Just Plain Need A Life
writeforus's Avatar
Have done my homework on ORC and all over the internet, but mostly I keep finding my same question asked repeatedly, and the answerers don't agree.
How do you take pitting, water spots and brake dust off polished aluminum wheels?
Instructions from Mickey Thompson on the wheels is so vague it's useless. CYA basically:
MAINTAINING M/T CLASSIC II AND CLASSIC LOCK WHEELS
M/T Classic II and Classic Lock wheels are not clear or powder coated. This means that the end user must maintain their wheels to preserve that “out of the box” look. There is no warranty on the finish on M/T Classic II and Classic Lock wheels, so it is important that you take the time to keep your wheels looking good. The follow procedures will help you.
1. Only wash your wheels with mild soap and water, then hand dry with a soft towel. Some commercial wheel cleaners and soaps, both for home use and at car washes, use acid or caustic chemicals and will damage the wheels. Wash as often as needed to remove brake dust and road dirt and grime before it accumulates on your wheels.
2. When you first get your wheels and at least after every fourth wash you should wax them with a wax developed for custom wheels. This will help seal the pores and prevent corrosion.
3. In areas where salt or sand is used on the roads in the winter, the wheels should be removed and stored until winter ends.
4. We provide steel center caps free of charge with every wheel purchase. These caps will rust under harsh conditions. However, aluminum center caps are available at an extra cost.
5. If corrosion has occurred on your wheels there are several off the shelf products that will help to restore the factory finish. Another option is to use 000 steel wool and WD40 to remove the corrosion, washing, and then polishing the wheel to restore their luster.
Suggestions? What do you KNOW works, with a product actually commercially available.
writeforus is offline
