YJ weak links
2075 Views 8 Replies 1 Participant Last post by  Pete88YJ
A freind of mine just bought his first jeep a 93 YJ with: 4.0 and auto, 4.56:1 gears, ARB's front and rear, OME suspension, 1" body lift, and 33x13.50 micky thompson claws. he has very little offroad driving experiance, if any, and plans on taking this on trails such as bassi falls and the rubicon this summer. I'm guessing that the axles are the first weak links, but what spare parts is he really going to need? thanks for any help
Jeff
'83 Toyota long bed
5" lift, YJ front springs
1 - 9 of 9 Posts
I think the weakest point will be the rear axle. If the rear yoke has not been changed or modified to u-bolt retention from the strap and bolt design, I suggest that is the first thing to do. The Dana35 rear is weak too, and I had heard that ARB cancelled it's locker for that axle for that reason. The auto is a good tranny, I suggest a tranny cooler if it doesn't have one. The slip yoke, if it's still there too, is not that great, but it should be ok. The dana30 front axle is really not that bad, and is considered stronger than the CJ dana30. Keep an eye on the front wheel bearings, as they can be a weak link. You can also upgrade to the larger ujoints in the half-shafts (if 93 didn't already have them, which it may - not sure if this was changed in 93 or 94/5). Also put a steering box brace on it if it doesn't have one already.
So, IMHO, the order of improvements would be:
1. get rid of strap and bolt yoke quick - go to u-bolts
2. tranny cooler and steering box brace.
3. rear axle - maybe upgrade to a 44 or a ford 8.8 - though the locker may cause you to break axles - carry a spare or 2.
4. slip yoke eliminator
Good luck
Pete
88YJ, 33s w/ stock axles, no lockers.
88YJ,4"susp,33"BFGMT,9kwinch,homemade swingout,258,999,4.10,weber32/36,GMHEI,one moonguy/wwwthreads_images/icons/smile.gif
See less See more
Well, since he doesn't have the crappy manual trannies in it, I'd have to say that the D35C rear axle would be my biggest worry.
As far as spares go, just the usual stuff.
_____________________
John
95.5 YJ with "stuff"
http://SonsofThunder4x4.com
2
I agree, without a crappy wrangler manual tranny to worry about I'd focus on Jeeps 2nd biggest plunder the dana 35c, square headlights being the biggest/wwwthreads_images/icons/tongue.gif. Since it already has an ARB and gears I'd go with the warn full float kit and the previously mentioned ubolt upgrade. If he's got the money and desire he can convert over to 5 on 5.5 and get real hubs on the front end.If not carry as many rear axle shafts as he can fit plus tools to change them. Sounds like a pretty sweet first jeep I'm sure he'll enjoy it.
Travis
Inquire about my witty original saying contest/wwwthreads_images/icons/crazy.gif
See less See more
YJ's biggest weaknesses are their drivers. They're all Yuppies, and don't know the first thing about driving offroad. A survey was done, and it was found that only .1% of all YJ's actually see offroad use. This was a plot developed in the mid-80's when the greenies didn't want anyone using THEIR land for anything other than nothing... /wwwthreads_images/icons/wink.gif
Actually, for a cheap and easy (you prob won't notice) the diff- get a K&N air filter, and remove the front restrictor.
I am finding that with 33's, the rear drums are fading quickly under hard stopping...
Jon - YJ94
http://www.obsessiveoffroad.com
See less See more
2
Sounds like it's time for a rear disc brake conversion there Jon /wwwthreads_images/icons/frown.gif. Or if you haven't regeared yet, swap in a Ford 8.8 axle. You get more strength, and discs all for about the cost of the disc brake set up for the D35 /wwwthreads_images/icons/cool.gif
John
See less See more
What do you mean when you say switch from the strap u-bolt to u-bolt retention?
They use straps and u-bolts to hold the u-joint in place. The straps aren't as strong as ubolts so many have converted them.
Go here:
http://www.off-road.com/jeep/tech/axle/aub.html
Pete
See less See more
1 - 9 of 9 Posts
