Well my 4.5" grinder gave out on me last night so I was stalled until today to finish removing the roll bar torx bolts. I found the easiest way was to just grind off the head! I got the roll bar out and set it in the YJ tub for the moment. I managed to move the tub about 5 inches to the rear and rechecked to make sure I had all the mounts and wires and other junk out of the way. Hopefully tomorrow I will be able to catch my friend so we can pull the tub off the rest of the way!!!
goodluck with the rest of the process.
Muddynut
/wwwthreads_images/icons/cool.gif 78 CJ7 "Issues" /wwwthreads_images/icons/cool.gif
hey patch... use grade 8 or stainless steel bolts for everything.. and before you bolt anything in... tap out the holes.. then spray that rust converter crap into them.. it bonds to rust or something of the sort.. i did that to my yj tub.. man its sweet.. every bolt went in to finger tight..
whatever you do.. GET RID OF THE TORX!!!!
http://www.jeepgod.net
84 CJ-7 401/T-18/D20/D44/D60w/4.10&Detriots/YJ frame & tub/35x16x15 Boggers
