If the box will bolt up to the frame, you should be able to make it work by changing the shaft ends. Then if you want to get a free dropped pitman arm you can bolt up a grand cherokee box, they already have as standard equip a dropped pitman arm from the factory. An xj box will also interchange with a wrangler. One thing you'll have to do is probably have new ends put on your ps hoses also. Somewhere along the line metric was introduced. I cut and welded my steering shaft as mine came from an xj so a little lengthing was in order. Good luck, Steve
Mopar360yj
D60-44-4.10
