It is definitely not just a matter of flipping springs. Driveshaft angles, steering solutions, brake lines, shocks, slip yoke eliminators, driveshafts, spring wrap concerns, axles, gear ratios.....
IMHO, any SOA is too complicated for a 'kit' to be worthwhile. All the things that need to be changed, the different axles that people may have, different driveshaft lengths that you'd need, etc. I just can't see that there's a good "fits all".
Your sig says you have a 4 cyl. and 31s. 31s would be too small for a SOA, and you'd probably need new gears for larger tires.
Then, it'd be silly to regear a dana35 rear, so you should get a new rear axle for the SOA, and the gears and larger tires.
Then, depending on the axle you choose (44, 8.8, etc.) will depend on what happens to your driveshaft lengths.
Then, you can go with a SYE. I think you can do a SOA without it, but that's not the best approach, IMO.
Then, you'll need a CV rear driveshaft.
Then, a front steering solution for the dana30. Z-shaped tie rod, or a high steer solution. Or a new front axle to match your rear. Perhaps change to 5 on 5.5 dana44s, like from a waggy. Or stick with the dana30 perhaps with an 8.8, and keep the 5 on 4.5. Then you'll need a steering solution for the SOA, as mentioned. Keep in mind the front needs to be geared to match the rear, so that's a regear in there somewhere.
The, Shocks, measure and buy once it's SOA.
Then, Brake lines, same, measure and buy once it's done.
Not to be a nay sayer, as I love my SOA, but there's a fair amount to doing one.
I hate to see people get into a job, and then find out later that all of these things need to be addressed.
Good luck
Pete
