Guest
·About 2 months ago I tore apart my YJs NP231 after determining that the driveline catching and grinding was happening internally. I found that the Range Shift Fork and Range Shift Hub were all chewed up and the source of my worries. I bought an NP231 with about 40K miles on it, and about 50 of those used off-road. I took out the compatable parts, replaced them, put it all back together, and it worked like a charm!
About 800 miles later, the Range Shift Fork has crapped out yet again (had to tow my rig from the Adirondack Mtns 3 hours home, quite the ride). I tore the Tcase apart once again and the Fork looks as if the Range Shift Hub was rotating real hard and fast, and grinded the Fork like a mill. I dont want to put it back together with a brand new Fork if its just gonna fail and require another rebuild. Now, I bought it with about 50K on it, and Ive put about 60K on this YJ, highway and trail miles, for the past 4 years. It has had 4" suspension and 33x12.50 BFG A/Ts on 15.5 wheels since I got it. My questions are as follows:
1. Has anyone had similar problems, or experience this with the NP231 or any other Tcase?
2. Could it just be worn down input and output bearings?
3. Does the Range Shift Hub rotate?
4. Is there something Im missing?
5. Does anyone have a Range Shift Fork floating around theyd like to get rid of, or a parted NP231. Im also willing to trade parts off my 2nd case.
6. Have the Tcase and its components seen their days with the added stress of the lift, wheels and tires?
Sorry so long, just wanted to make it clear. This is the 2nd time Ive had this thing in parts, and Id like to make it work longer than 800 miles. Any feedback is greatly appreciated. Thanks!
Jason (Im going through Jeep withdrawel, and as if the DTs werent bad enough, my only other rig is a Toyo Corolla
) Dunn
