My kids YFM 80 is making a nasty clattering when it is shifted into 2nd gear. It is an automatic. Could it be a clutch adjustment? If so, does anyone know how to adjust it?
check to see if your pinion gear is tight , if the nut walks off a little you will get a nasty noise from that. But to adjust the clutch just above the shifter there is a black gromit, remove it and loosen the lock nut and use a screwdriver to adjust it. The only thing is this will only help if your clutch is slipping.
