Well the long avaited moment arrived. This thing blows good air! /wwwthreads_images/icons/smile.gif Now what? I ended up using a TJ belt (no I don't have TJ envy) /wwwthreads_images/icons/smile.gif and routed the belt as was suggested by Brad Kilby from onboardair.com using the TJ belt routing. As it turned out the belt was almost a little short cuz the TJ idle pulley is a little smaller and my botched compressor mount bracketry is a little higher than stock. Oh well I made it fit by loosening the adjuster screw all the way. That took me an hour cuz it was rusted and I had to take the hole power steering pump and bracket off to be able to get the screw out so I can clean it up and get it going. /wwwthreads_images/icons/crazy.gif I test ran the engine up to 3000 rmp for a short time and it didn't throw the belt. Actually the belt was not warm or appear to be grinding anywhere so far. Amazing, given the fact that the compressor was basically eye-balled in place. Keeping fingers crossed and spare belt in tool box though. /wwwthreads_images/icons/smile.gif The thing is actually pumping pretty good air. Maybe it's not a York but Brad said that this older model has actually close the same displacement as the big York compared to later Sanden models which were smaller. Whatever it is it's got good pressure even at idle. Now what do I need to get to get the air to the tires? Once I'm done with this it's onto the onboard welder. (while waiting for the locker for my 8.8 rear)
Here are some pics:
http://www.webphotos.com/member/7612/138604.jpg
http://www.webphotos.com/member/7612/138605.jpg
http://www.webphotos.com/member/7612/138607.JPG
http://www.webphotos.com/member/7612/138608.jpg
'91 YJ,I-6,2.5" lift,Boomerangs,33s,D30,D35c,Lock-Rights F&R
Here are some pics:
