Has anyone put a Wrangler tub on a CJ-7 frame, if so how did it mount up?
Did the body mounts match up? if so how many? I heard a few mounts don't
quite match up but a most do and that isn't hard to fix the ones that don't match up.
If anyone one has any input I would greatly appreciate it
Elusive has done it.. the ones under the door way dont match up... you can just put a piece of flat steel across there and redrill them.. not sure if there is more to it than that.. you would have to ask Elusive.
Many of us have done this...
In addition to jeepskate site, check out mine, particularly if interested in using a CJ Tailgate.
Bodymounts:
The mounts immediately in front of the rear tires do not line up. You have 2 choices, move the mounts on the frame, or drill a new hole in the tub. Also the mounts on the rear cross member do not line up. The need to be moved out about 3/4", a die grinder will do this... I had to replace my rear crossmember so I just relocated the holes..
Minor issues with the dash mounting holes. The Defroster will need some attention.
Jim O'Brien
[email protected]
My jeep page
