I just hooked up an MSD system to my 258. Should I put a fuse inline where it connects to the pos. battery? Also, just curious to what everyone thinks about the MSD system. What about a push start button, how do I go about hooking one of these up? Thanks for any help.
I'm installing one in my Ford F150. Completed the wiring and fired it up for the first time last evening and the engine ran badly. Now, I will follow MSD's instructions and replace the plug wires, distributor cap and rotor which are all in bad shape. I expect that should help a lot.
My instructions said the MSD is fused internally and to wire it directly to the battery, so thats what I did. I would be interrested to hear how the unit performs for you in your Jeep.
I have mine wired direct to the battery. No problems so far. The MSD
definitely helped both the starting and the idle (even with the Carter
Burp-Burp-Die carb). Can't say it helped the MPG much.
Ron R. - 90 YJ w/OME
