What guage of wire are you running? I have to run 4 guage on mine, I have a MTX 775 watt momno block that won't run off anything else. Any time I've ran 4ga, I drill a hole, and use a plastic snap in grommet. Imay seem like a bitch of a task (especially in XJ's, with hardly any room to fit a drill under the dash) but if you are running 4ga or bigger, it's less time than working that stuff through a factory grommet. BTW, if you drive an automatic, there is almost *always* a decent spot to drill or a premade grommet where the clutch would've been if manual. Enjoy!
