I found some Autolite wires (P/N 86168) that looked like the connections were right. These wires are 8.5mm wrapped silicone for about 20 bucks ; is that what I want? The coil wire was 9". Would the TFI coil be okay mounted on the engine block. The motorcraft wires (WR-4050) are 50 bucks and I can only find them at a dealer (grab your ankles). I also found a one piece cap that had the high output terminals and it looked like it would fit my distributor. Do I need to stick with the two piece.
I hope you're not getting too tired of this subject.
Thanks, Larry
Thanks, Larry
