ok .. i did a search.. so now i`m here ..this is for a buddy of mine he`s got a 84 ranger efi 4 banger.. and this is what it`s doing.. if he turns it over it would start but a soon as he lets the key go from cranking it dies so i said well try.. to pull the starter wire off after it fires..sure as soup. .it ran ..for a little bit then died.. he did all the normal stuff " it`s got gas.. power to coil..and so on" with out doing a pile or wire chasing ... is there somthing he should be looking for..if someone could help him out that would be great...
JB
under the kick panle on the pass. side.
check for a relay,thump it with your finger,
or look to see if the points inside are closed.
