Guest
·I have a 1983 CJ7 with a inline6 4.2L Need lots of work. Idled fine and run okay when I bought it this summer. Know it will not idle. I think it started after I replaced the timing chain (not sure). Have been massing with it for a long time.I can set the timing with no problem. Check top dead center right on. Has new plugs, wires, cap and rotor. I have a different carburator on it and it still will not idle. Know that it is cold. When the choke is on it idles on fast idle. When it goes off it will not idle. The fuel pump has 6psi at idle.I installed a clear line and has no air. I even ran it out of a gas can still will not idle.I drive it everyday to work and it runs good going down the road. But when I shift gears the rpm's hange up alittle. I have replaced the head gasket for a different problem. Plus I have sprayed ether around the carburator the intake and there are no leaks. When I get it to idle. It has about 18 ins of vaccum. But the gauge says that the timing is off. I'm all out of ideas.
Thanks Quack
Thanks Quack
