Will 33x12.50x15 on 8\" rims fit....
a 82 CJ-8 with 1 3/8" shackles and stock CJ-7 6 spring, spring pack which replaced stock 4 spring, spring pack?? I know it sounds rather vague, but here is more info on it. Hopefully it'll shed a little light on my question:
I had to remove the swaybar end links since they about 2" to short with the Jeep setting on level ground.
I had to get shocks that are for a 4" lift vice a 2" lift which the shackle lift only required.
I truely need about 2" longer brake lines, but they will do for now.
I currently run 31's and have all sorts of room in the fenderwells. But, I know how deceiving this can be. I have more clearance with my Ranger on 36's and still smack the fenders off road. Thanks.....
Sorry about the confusion earlier....I didn't proof-read it.....
Re: Will 33x12.50x15 on 8\" rims fit....
Judging by the length of the shocks and the tightness of the brake lines, sounds like 33's would be a good match. Stick with the 8" rims though, 10's would cut down on your turning radius a little more.
