Will 31x12.5 tires fit on stock \'88 Pathfinder?
Anyone know if 31x12.5 tires on a 15x8 rim with the stock 4 7/8 backspacing will fit on an '88 4x4 Pathfinder? The suspension is stock except for stiffer Sway-Away single stage torsion bars. No body or suspension lift. Any info would be appreciated
Re: Will 31x12.5 tires fit on stock \'88 Pathfinder?
What did you find out on this?I would be interested.
The 31's no-problem, the 12.50's I think you might need more back-spacing on the rims, but I'm not positive. The Stock rims are usually 7", so you might need something more like a 3" backspacing???
Chris J.
/wwwthreads_images/icons/wink.gifIt's not the Biggest, but at least I use it!/wwwthreads_images/icons/wink.gif
