**TR, you accurately described all AMC engines with slight exception to the 401 which has a steel crank.**
The question was what was wrong with the 304, not what was right with the 401.
**I wouldn't trade my 360 for anything, except maybe an EFI HO 302w.**
Why not go to a 351W?
50 more cubic inches in the same size and weight package.
**There are probably bunches of better engines out there but nuttin but an AMC will bolt up.**
True. Very true.
If I don't use some sort of exotic (Exotic defined as anything but small block chevy, small block Ford) I'm probably going to use the 360 I have in the garage I can't get rid of....
Everything bolts up if I use it.
** TR, as far as the "poor block" i have to say youre wrong. due to the high nickle content AMC v8's are fairly strong blocks. also, the oil flow is "workable." drill and tap two holes into the rear lifter valley and plumb from the front for better oil flow to the often starved rear mains.**
High nickel content wasn't used in anything but the 390 & 401 'Hi-Po' castings, and wasn't used at all before 1969 and not after 1974. (You can thank the AMX for that)
A nickel content higher than Chevy or Ford was used because of the pitiful water flow direction and shifted castings.
With out the extra nickel (a long way from High nickel content) the block would fall apart when heated and cooled.
(Check out Joe Mondello's book on AMC engines that just came out, it's REAL interesting! He gives up all the secrets of the factory AMC racing team.)
Also, I was speaking more of the air bubbles in the material, over casting and flash casting, blocked internal passages, missing water flow guide baffles, shifted sand casting leaving thin odd shaped cylinder walls and internal webbing not connected to anything...
As for the oil system...
It sucks totally.
The oil galleries never line up correctly, the drilled galleries are always misaligned, the crank is starved, the cam is starved, the entire front end is DRY!
I'd call those problems...
The question was, "Why do we rag on the 304", not, "How easy is it to clear up AMC poor design"
Chevy has the best internal oiling in the business.
Good cast passages and galleries, and very good alignment of the drilled passages.
Oil where you need it, and no oil where you don't.
The SBC need a better head design with canted valve angles and that &%*#@ HEI distributor is junk.
The Vortech heads do help the top end breathing problem quite a bit, and a just what the doctor ordered for Jeepers! (Under $400 for a complete, ready to bolt on brand new set!)
You can get a 4 bolt main block, forged steel crank, forged steel connecting rods, good heads, a dozen types of fuel injection, good heads and a transmission to satisfy anyone, ALL FROM THE JUNK YARD!
Small block Ford has serious top end oiling problems.
Anyone that has had to do a top end on a 50K engine knows the entire top end is shot from lack of oil.
Use sealed roller rockets to get around that problem, and the little Ford does a good job.
Fair ignition (Meaning it's easy to tune and add a MSD module to) Good flowing heads, strong blocks, heavy nodular iron cranks and steel rods, along with Hot Diggty! fuel injection for cheap out of the junk yards.
The draw back is Ford transmissions can be finicky when you try and bolt them up to some transfer cases.
The little fords are everywhere, cheap and strong runners. The only draw back is they are more expensive to build than SBC.
AMC engines are heavy, clunky, outdated technology that has no factory updated parts since '78.
Internal oiling is crap, external oil pump is crap, no available forged steel parts, ect...
See above.
