Guest
·ok i wanted to know what gears i had in my cj the first thing that threw me off was that the amc axle code didn't match what off-road.coms tech section says. i know i'm looking in the right place cause i have checked other jeeps and found a code that matches what is on this page.
so i take the front diff cover off cause its easer then those damn torx bolts in the back. the ring gear is marked 43 and i counted 43 teeth on it. i counted the pinion gear 3 differnt times and come up with 14 teeth. divide 43 by 14 and you get 3.07... cjs wernt supose to come with 3.07s
and i doing something wrong? its a dana 30 cause the ring gear has that maked on it too. any help would be great.
80 cj7 304, WC t-5
80 cj7 304, WC t-5
