Who Makes 33 x 11.50 x 15's
12543 Views 13 Replies 2 Participants Last post by  **DONOTDELETE**
Who Makes 33 x 11.50 x 15\'s
I am having trouble finding this size tire. I need this size so that I can run my stock rims. 12.50's are two wide and 10.50's are to narrow.
Thanks in advance.
1998 Jeep TJ
1 - 14 of 14 Posts
Re: Who Makes 33 x 11.50 x 15\'s
swampers are made in a 32x11.5 size. and the are actually taller than most other brands 33s. give them a try.
dan
What width wheels are you using?
Gary
I am using 8" rims. Dont get me wrong I can use narrow tires but I want to go as wide as possible for my stock rims.
1998 Jeep TJ
You can run most 12.5 wide tires on a 8 inch wheel. or are you lacking room for the wider tire?
dan
It's a back spacing issue with stock rims rubbing. I run 31x11.50 on stock 15x7's and had to add 3 washers to each side's steering stop to keep the tires off my springs
_____________________
John
95.5 YJ with "stuff"
http://SonsofThunder4x4.com
Okay. If it's a backspacing problem, I see the reason for the narrower tires.
Gary
What about Buckshots Radial Mudders??
Their 275x85x15 are close to 34" tall and almost 11" wide. I personally love this tire and most reviews I've read like them as well. But, I've also read that they could be a little better tire in the rocks.....
Re: What about Buckshots Radial Mudders??
Okay, on the Buckshot radials........... Do you think they'd last longer than radial Swampers?
Do they have anything in a 32x10.50?
John
The narrow (31x9.50, 33x10.50) Swamper Radials actually look like buckshots, so I'd guess they'd wear about the same.
TEX
G.U.M.B.O. Mud Racing
See less See more
most of the buckshots i have seen wear very well. but that also means that they have a harder compound.
dan
I do not intend to offend,I offend with my intent
Thornbirds come in a 33x11.50 size.... Although I would look at the tread before I bought them. I just got a set of 33x12.50's and they have quite a bit more room between the lugs than the 33x10.50 (my spare). The 12.50 is altogether a different tire! The 10.50's side lugs are weenie the 12.50's are huge.... HTH
Matt
Never under-estimate the power of stupid people in large groups.
31.5\" x 9.6\" is...
the closest they have. They are 245x85x15's. I personally have a set of 315x85x15's on my Ranger and I love them. They have around 5,000 on them and still look new (unlike my 33" bias Swampers). I bought mine from National Tire & Wheel (http://www.natltire.com/) and haven't regretted it since.
Chris
Re: 31.5\" x 9.6\" is...
Stan- who makes them, and what kind are they?
John
1 - 14 of 14 Posts
