My gas gauge is going nuts. it will pulsate and stay all the way to full, then go down. I have a brand new gauge, brand new sender. brand new wires, good ground to sender, no crimped wires. I think my Cluster is not grounded properly. At what point on the cluster should i run a wire to a ground source? Looked at the electrical diagram and it doesn't give an exact point. I repainted the dashboard and i don't want to scapr paint to attach the wire, so i am going to run is to a grounding strap. I hope some guys with fiberglass tubs can give me some hints, because i would like to get the fuel gauge working for this weekends trip.
Thanks in advance
Dan Stewart 1963 CJ5 "Caloosa Jeepers" member
The Speedo cluster grounds through the dash. On my 83 CJ I've just swapped tubs to a fiberglass. I ran a 16ga wire from the bottom lip of the dash to the battery ground, it works fine... and cannot be seen. Have you checked Jaffers site yet?
http://www.monsterslayer.com/jeep/Gauges.htm
He has written the bible on CJ gauge diagnostics....
Good Jeepin'
Larry
Hey LEVE or Jaffer was the site recently revised? It looks different from last time i looked. It still has great knowledge. I will recheck the gauge when i pull it, but since no magical smoke left it and it still works, i.e. goes up to hot then down and back, i guees i have the wires correct. So the whole housing of the Cluster is the ground point? So if I ran a wire to the mounting point of the gauge to Dash, to the ground portion of my fuse block, then it would be properly grounded? I hope this will work.
Thanks for the info
Dan,
Did you repaint the back side of your dash also? If so you probably don't have good contact between the gauge cluster and the metal of the dash. If that's the case, running a ground wire from the dash to battery ground won't help. Run a grounding wire from the gauge cluster itself.
'75 CJ5,258,T18a,4.27's,33's,On-board air,Warn 8274
Dan-
I grounded everything to the Speedo housing at it's four studs (see yellow insulated terminals) then ran a 12 Ga ground wire from the lower left Speedo stud nut along the dash's bottom then down to a spot just above the brake release handle. There is a tub panel seam with an interior protruding lip so I drilled a hole and grounded it on the back side of this with a bolt and star washer where it is out of the way and out of sight but easy to get to.
CJ-Dave should be proud of me...
JAF
Thanks Jaffer. THat picture is what i really needed to see. I will run a ground to the speedo bolts like you did. And hopefully i can tell how much gas i have, gasoline that is /wwwthreads_images/icons/blush.gif. You did an excellent job on your site with the gauges. Keep up the good work.
