Guest
·I have finally decided on how to lift my postal. The rear is SOA (from the factory), and I will use a combo of extra stock lift blocks and a couple of extra leafs in the spring pack. I've got another postal that I can scavenge them from. In the front I plan on cutting the (hollow) axle tube, rotating it 180 degrees so the spring perches are on top (Spring over!!)and using stock springs. I was only looking for 2 inches, but It looks like I might end up with three or four. I will need to extend the brake hoses. What can I use without going to aftermarket stuff? Is there a car or truck with stock hoses that are longer? What should I look for other than length, obviously? Is there a standard diameter or fitting size? You guys are the master swappers and I have faith that you will come through for me once again.
--Laugh and the world laughs with you. Cry and the world laughs at you.
