1 - 13 of 13 Posts
like the stuff that comes with lift kits? would home depot or a REAL hardware store carry them?
My local home depot does not carry grade 8 stuff. The local ace hardware is where I get my grade 8 nuts and bolts.
Brian
farm and fleet or ace around here.
Home Depot carries Grade 3, it doesn't even have marks on the head. I get mine from a truck parts store or we have a local nut and bolt store that supplies factories. He has everything.
Literally in your back yard....I think the place is called Little Rock Bolt...look in the phone book. I thought their prices were cheap for Grade 8 stuff when I was over there...as long as you know the diameter and length, they likely have it. Lots of industrial shops over there too. I think they are over near Markham or Univ....does that sound familiar?
thanks birddog! i looked them up and they're out near geyer springs.... if the local hwd str doesnt have the goodies then i'll try them
hmmm, good question havack... the secret will be revealed tomorrow
birddog, you da man! i went over to LR Bolt and get 10 grade 8 bolts and nuts, AND 6 screws for my lockout all for under 5 bucks! that place kicks some asss!
havack, 2 warn premiums are in the mail! expect them in 2 days... hell they're probably already in memphis
everything you need to convert to them should be in there, post pics of the swap!
that's all for now, if i finish my super secret project tonight i'll put up the pics for all to see
Discussion Starter · #11 ·
Re: Nylok nuts?
nope, just regular nuts with some weird markings on them. i asked the guy what max torque i could put on them and he said 85 lb ft, i'm assuming he meant 850 lb ft so i'm going to get them really tight
i know they're easily good for 150, so that's what i'll do em up to. but i wonder what exactly i'm doing with them?????? stay tuned to find out
Theres a little bald man that sits in the back room of LR Bolt stamping those imported bolts with 5 notches....I think thats why their stuff is pretty cheap - I know you need to hear that after staying up till 3 working on your project...I also found a place that sells mining equip about 7 minutes from LRB that has shackles (and not that Chinese crap!!!!!) up to the size of a boat anchor and other recovery gear...I dont recall the name, but its over by all the recycling areas in a way bad part of town.
Discussion Starter · #13 ·
how did you know i was going to be up til 3 working on this project? i just stopped for the night and (weird!) it's 3 am! anyway, that place sounds cool, i'll try to figure out what it's called and go browse their selection. gr.8 is way overkill for light truck stuff anyway, a grade 5 bolt would probably rip through the frame before it'd break so i'm not that concerned even if some bald man painted these bolts gold and put 5 (i think these actually have 6) notches on the head.
1 - 13 of 13 Posts
