i have a 92 jeep wrangler i'm doing the rear wheel bearings on and i'm trying to get them out wiht out the bearing removal tool mentioned in the hayes manual can it be done what i have tryed so far was a piece of flat stock with the ends radiused to the radius of hte tube then a slot cut in the center with a bolt going through it to my slide hammer but i cant get them to budge do i NEED the special tool??
TugBoat Proud owner of a 1992 JEEP Wrangler YJ
4Cyl 2.5L w/ 5 speed manual tranny
totaly stock
Sorry to burst your bubble, but those things aren't comming off with no piddly slide hammer. Somewhere during this operation, you will need a press.
I think somebody here had a little easier method of getting them off though, saw a write up on a web page a while back, if anybody remembers, please post it.
1) Take a grinder or dremel tool, cut the outer cage for the bearing. This is fairly easy. Just cut the collar and peal it back.
2) Once the outer collar and and rollers have been removed, and this will leave you with only the inner collar.
3) Score the inner collar with the grinder/dremel, about 1/2 through the material, being CAREFUL not to touch the shaft with the cutting tool.
4) Take a hammer/chisel and hit the score to part the remaining collar.
You will need a press to put on the new bearings. I would suggest heating (boiling works well) them prior to pressing them as it will make things go easier.
'83 CJ-7 nothing original but the tub and axle tubes
sorry i should have been a little more specific my 92 has a 35c which has the clips adn the bering isn't pressed on the shaft it is in the axle tube anyoen have any help??
totaly stock
Official Historian
Do you have an Autozone near you? For a deposit, they will loan you the bearing slide hammer with 3 jsws. Take the tool back and get your deposit back.
well i went and got the tool from autozone after about 2 hours neither would come out so my brother gives me some last chance advice GRAB A FIREXTINGUSHER and the welder turn the welder way up and weld a bead along the inside (center curcular most edge) outer most part of the race now this didn't totaly fix the problem so he sez cut the buttom weld it just enough to make a cross cut on it dont' touch the tube that part being liquid for a second released all the presure used the tool and it came right out brother sez grampa taught him that one man i wish i would have been a little older when grandpa was still around so i could have learned this [censored] too.
hope this helps someone out sometime oh and if you have any doubt in yoru stick welding skills DONT DO IT
totaly stock
