What\'s Your Orientation ??......
I thought the post title would get some attention.....
Orientation in regards to Mopar mounts........
Seems like folks install them in a variety of ways....
Some lower, some raise, some move rearward etc. etc.....
Mine raise the motor with a less than perfect fit....
Re: What\'s Your Orientation ??......
I did a 16 valve conversion some time ago with a set of the Mopar mounts and was less than pleased. The mounts were a pain to install because they had to be stretched so they would meet up with the metal motor mounts. It also did not sit as level as I would have liked. I have used these mounts several times and when used only on the drivers side the installation is tolerable with the motor leaning a tiny bit to the drivers side. The early Sidekick mounts are cheap and easy to find and work very well since they are the same size as the Sammy mounts, but ALOT stronger.
Sean DeVinney
