What\'s too Tight?
Front end specialists needed...
I replaced my front springs with new stock springs last week. It steers and stops straight. But...on a left hand turn the steering wheel stays about 45 degrees to the left instead of centering again. A right hand turn and the wheel centers correctly. This happened once before and the bearings in the steering knuckles were bad. I replaced all four of them about 4 years ago, shouldn't be bad again so soon. The knuckles are lubricated and seem tight.
Ross steering, recently replaced the bellcrank and the drag link is adjsuted properly. I did have one screw up though while replacing the springs. Trying to do them one at a time I had the left one installed and then with a jackstand under the lefthand side of the axel removed the u-bolts from the right side which caused it to shoot up in the air (smacking my jaw in the process, duh). I think that I may have bent the left spring. Would this cause the problem? I'm probaly going to take the whole (*&^( thing apart again this weekend (my daily driver). Should I look for anything in particular.
Thanks in advaance for your inputs.
