my light duty 3/4 ton has a GVW of 7200, Im wonderin how much of a dif there is between the two, probably not much.
Thankx
The Kid
It never fails, when Im turning wrenches on my truck and something can go wrong, it usaully does
my 3/4 ton is an 8600GVWR Longbed reg cab
My 1/2 ton SW says 6100/2767 GVWR I guess that means 6100, but with nothing in it it weighs 2767lbs.
>>>>>>>>>>>>>>>>>>>>>>>4x4
I just wnated to know how much of a dif there was between My 3/4 and the 1/2 tons, looks like about a 1000 dif.
Thakx for the reply
Good post, I have been troubled by the GVWR of my truck. I have a 98 K1500 ext cab short bed and the sticker reads ... no joke... 6200 lbs gvwr. Now the truck weighs around 5500lbs empty on the quarry scales. So I am estimating about 3 fat chicks can be loaded into the back of the truck before I get a ticket or 85 gallons of water. Now for another twist to the topic, I can go to the licensing place where I buy my tabs and get the rating increased to 10000 lbs gvwr for 20 bucks extra per year. My truck can't handle 10000 lbs safely but I would be legal. Now if I got in a wreck I think it would be my fault because I was overloaded and couldn't stop soon enough even though I am legal to be carrying that much weight. To increase the weight rating above the sticker I think I would also be required to put a sticker on the side of the truck stating the new weight rating. My owners manual states that I can tow 6500 lbs. The same truck but a 3/4 ton can only tow 6000 lbs. WTF? I must say that I've loaded more than 3000 lbs of rock into the rear of the truck and my weight was just over 8500 lbs and while the butt sagged, I had full control and the ride felt stable. Another note, 2000 lbs in the rear of my half ton just barely allows the snubbers to touch the suspension so I feel pretty good about upping my weight rating to 8000 lbs.
um...just a note in case yall are comparing trucks - 2wd are rated slightly higher than 4wd. like around 500lbs or so
Mike ~
* Earnhardt Forever *
89 Chevy K1500 - 350TBI/700R4/NP241 - 3" lift - 33's
highbeam,
Im not sure wether you relaize or not, but i have the light duty 3/4 with a GVW OF 7200 campared to the 1/2 tons 6200.
Ive hauled mabe 2000 before and my truck was realy light in the front, so I think I need some over loads to haul that kinda weight, It was sheet rock I was hauleing Im just guesing it was around 2000 pounds.
The kid
