Re: What\'s The Best Samurai 2\" Lift Kit?
Glenn,
We agree on the 7"+ shackles, but yet again we differ on Steve's S/R. Imagine that.
The sammy, like other trucks, came with the rear sitting higher, especially the soft tops. Those who owned their sammy since new will probably remember this. The rear being higher than the front is common to many trucksand the proliferation of "leveling kits" for pick-ups and such attests to this. Expected load in the rear (be it payload or passengers) is why this is so.
2" longer shackles front and rear only raise 1", because only one end of the sprint is raised. Therefore the center of the truck goes up 1"
The 2" S/R lifts the front a true 2" by lifting both ends of the spring 2". This effects the lift of the rear when extended shackles are put on the rear spring. I do know this, when I installed mine, I got 2" in the front, and a c*nt hair under 2" in the rear. The center of my frame sat 2" higher of the shop floor than when I started. But since my rear already sat higher, my Sammy sat level for the first time in it's life.
I ran 29" tires, and using the correct bumpstops, I never hit my fenderwells.
Although you may detract, the lift does what it claims. And because of that, I recommend it as the best 2" lift.
