What vechiles came with the NV4500?
2143 Views 5 Replies 0 Participants Last post by  **DONOTDELETE**
Does anyone know which vechiles I could try to locate in the boneyard that would have this trans? Also if I did find it what would be invloved in mateing it to a dana 300 and then to a ford 302 V8 motor in a 84 CJ7. Just curious. Thanks
Dodge and GM fullsize trucks come with this trans since the early 90s. Check Advance Adapters for adapters required. Their manual/booklets are excellent references. Hope this helps, good luck.
CJ-8 is right Dodge and GM since 92. I believe that you need to look for 3/4 or 1 ton, as far as I know 1/2 tons didn't use the 4500.
"My other car is a BULLDOZER"
If you have trouble finding an NV4500 at a junkyard for a reasonable price, 4WD Hardware sells them complete with the adapter for
$2,000. That may sound steep, but add up what the junkyard tranny, the adapters, and new bearings/ synchros will cost and go from there.
Gary
Gary has a good point. While these trannies are bulletproof in small Jeeps this isnt the case when they are in the bigger trucks. The truck owners often abused these trannies and a lot of the junkyard units are in bad need of a rebuild. Rebuilding one will cost a fortune.
Find one with low mileage!
LarryM
'85 CJ7, 350TBI, T19
'00 TJ, 4.0, NV3550, D44
3/4 & bigger is correct. For instance, my '96 Dodge Ram 1/2 ton came with a NV3500 tranny. Five speed manual, just one size down from NV4500.
John
'80 CJ7
'84 CJ7
'76 Scout
NRA Life
Join the NRA!!
