I am trying to determine what year engine/head is in my 79-CJ-7. The valve cover is held on by 3 bolts on the passenger side that go through the valve cover into the head, one bolt in the front that goes through the valve cover into the head, and 4 bolts with big washers (looks factory) that dont go through the valve cover but the washers seat into a recessed area of the cover and hold it onto the cracked plastic cover onto the head. Any ideas or comments on this???
Your head is most likely an '81 - '86 4.2l. Usually there is a date cast into thedrivers' side front of the head, (81,82,83,84,85,86 etc) between the front 2 studs. Hope this helps.
I just looked and i saw a "2" in the spot between the 2 front bolt on the drivers side of the head. I assume that means that the head is an 82? Is that correct??
Kevin Speicher
President
The New England 4x4 Club http://www.ne4x4.com
79 Jeep CJ-7
Off Roading Forums
