The SR-4 isn't worth putting gear fluid into. Let me take a guess on the shifter, the bottom stub broke off or wore out? My SR-4 didn't even last behind the original 4 cylinder, If you have a 350, swap in an SM465, you won't regret it, you'll never kill it, and they're cheap. If the shifter is curved, it's the SR-4, if the shaft is straight, it's the T-176. If the tranny works fine now, give it a few months, it'll start to die on you.
JEEPN
'81 CJ-8 Scrambled!
