What size tires are you all running on your rigs.
3.5K views 67 replies 43 participants last post by  Wyld_Bill
HI, I though it would be a interesting post to see what size tires you are running on your rigs.
my Samurai is running 31x10.5 r15 BFG AT's on 15x8 2.5 BS rims.
What's on your rigs?
#52 ·
Hi Rich, I'm running 30x9.5x15 Radial RVTs. Anything larger would rub with my SPUA YJ setup. And I refuse to go SPOA cause of the headaches. Perhaps with 4" lifted springs I could get 32s under there? Next project!
#53 ·
Re: What size tires are you all running on your ri
On one Samurai, I have 215/60-15 weenie tires on stock rims. The other one has 33x14.50 Super Swamper SSRs on 2.0-inch backspaced 15x10's, which after a couple years I still feel are the best tires ever made. And since installing these tires, I haven't broken a Birfield yet! My old 33's caused me to break several (4 or 5) but with the SSRs, I can be a lot easier on the throttle since the tires just stick so well to whatever terrain I'm on! I can idle up most stuff instead of having to romp on the gas. But for anyone considering these SSRs, be forewarned, they're easily a size larger than a standard tire; these measure about 1 inch taller and 3 inches wider than my old 33x12.50 Cordovan Radial RVTs, which were not small 33's. These 33" SSRs are about the same height as the 35" Baja Claws.
-- Geoff Beasley
#54 ·
Geoff, you need to post a head to head picture of your rig with those new whacker flairs on it...
thanks all for the information, I was thinking that you all ran larger than 31" tires, but I can see from this posting
that the median size is 31" that most of you are running...
cool looking rigs that you all posted...
thanks
#57 ·
Brown...
I am thinking of running the 11.50 LTB combo you have, what wheel back spacing do you have? any pix's?
Jim
#64 ·
Re: What size tires are y\'all running on your rig?
I got 32x11.50x15 courser MTs on 10" Centerline Hellcats.
They don't hold the bead well at all if I air down, but I got all 5 cherry rims for 200$ couldn't pass at the time. I need to go wider on the tires or get new rims now.
Can you say 33x14 boggers?
#65 ·
Ok - current tires are 235/75R15 Big O bigfoot XT's
new ones, that are going on after I swap to 'real' axles, are Power King Super All Trac's, 900x16 ( approx 34.25x10" flotation size) I've used the Power Kings under a Number of Rovers, and can tell you that the grip on a lugged, siped, and studded tire like this is just incredible. the narrow width makes them way easier to handle on road than a normal mud tire.
DD - the 5 on 4.5 bolt pattern is for my axle swap/s: Front XJ high pinion Dana 30, rear Ford 8.8", not for any kind of suzuki axle.
chris
