Dorian,
You have seen the pictures of my 89 set up.
I would suggest modifications to go an eye to eye install in both the front and rear, and while your at it move the lower mounts from below the axle front and rear to about the Center line of the axle tubes. I dont know the model number, but with mount modifiactations and relocation you can install the 33" shocks with 16" of travel front and rear. I just order them as 33" R9000s with bolt mounts both ends. I also installed the in cab adjusters for front and rear yesterday, the rears are up and running the front still has R5000s but the plumbing for the air lines are in place. I plan to replace the fronts with the 9s as they come up lame. It was most beneficial to have the adjustability in the rear because the 45 deg angles on the rear shocks make them much more reactive to the soft/firm settings.
Jeff
89 Wrangler
