Guest
·I'm looking for the ideal axles to put under my narrow track CJ 7. I'm looking for a 1/2 or 3/4 ton axle without C clips. I was originally going to go with full width Chevy axles (about 67 inches if I remember correct) but the Dana 60 is to heavy and expensive and the 14 bolt is way to big and too low to the ground. Then I was going with Scouts (58 inches wide I think) but I'm not sure if they are wide enough since YJs are about 60 inches. These will be used for some pretty extreme rock crawling but only motivated by a torquey V6 and 35 inch tires (yes 35s seem big for the v6 but I think I have the gearing figured out). So what is the idea axle front and rear (without being custom cut or spending a lot of money) in your opinion. Any thought would help since I keep going in circles. Thanks.
Tim Springer
1980 CJ7
Tim Springer
1980 CJ7
