What are the dimensions to have a Ford 9 inch rearend cut to fit my 89 Wrangler????????????
I'm loooking to put a ford9 in the rear of my Jeep in a couple of weeks. My question is how to measure to find out how wide or narrow to have the axle cut to fit. Or what are the dimensions from people who have previously done this.
Re: What are the dimensions to have a Ford 9 inch rearend cut to fit my 89 Wrangler????????????
Make it the same as a Early Bronco
It will be a little narrow. 1.5" on each side too narrow if you use the early bronco housing. BUT if you make up for it with spacers and wheel offset then you have the ability to buy spare axles really cheap and not have to have them custom cut.
Aaron
