It looks pretty fscked to me. I wouldn't have spent more than $50 on it. And I've bought some real "gems" for axles.
The ring and pinion are junk. The carrier is junk. The spiders are such junk that it's scary. All of those pieces of metal went somewhere so the axle shafts are probably junk from metal getting in the bearings and ruining the bearing surface on the shafts. Unless I'm mistaken, I see a ring gear spacer in there and that's what probably screwed up the whoever installed the gears.
Basically, you bought a housing, a differential cover, backing plates, a yoke, and parking brake cables. If you're lucky the shafts are still good. I hope you didn't pay much for it.
