As far as heating it with a torch - it should help - a little. Never tried it except on cast iron, pre-heated it, kept it hot afterwards for a slow cool down. Sometimes it worked, sometimes not. He He - funny - welded a cast thing once torch preheated, torch afterwards for a slow cool down. Looked good I was proud of myself! It was just sitting there cool enough to touch - BANG - pieces exploded everywhere!
Remember - welding is not dribbling filler on a joint. Welding is getting BOTH surfaces hot enough so the metal FLOWS and merges together. BOTH surfaces have to be heated above the melting point to do that. The thicker the material, the faster heat is carried away from the joint.
That's one reason why aluminum is hard to weld.
When welding - WATCH THE PUDDLE - NOT THE DRIPS! Move the puddle along - you can see how it's penetrating. Use magnifier glasses if needed - I do.
Yes, you can use a toy welder to weld heavy stuff - even make it look good. But put it under strain and you find out it's a cold joint - not strong at all. Similar to a cold solder joint! Usually one side pulls off, leaving the bead stuck to the other side. Look close when you see that, you can see how the weld didn't melt together.
Heat is the key - fast and lots of it - but too much heat for too long is bad too. It burns/boils the carbon out of the steel - carbon is partly what makes it strong (like burning holes.)
It has to get to temperature, melt together, then cool, but not too fast either. Too fast freezes the carbon in the wrong spots - called Markesite - brittle. Not good to quench with water - too fast.
Try something - make a weld and let it cool in air.
Make another and quick bury it in sand (cools slower.)
Quench another with water.
Now try drilling a small hole through each of those welds.
water quench - very hard - breaks your drill.
air - hard but drillable.
sand - almost like butter.
----- there - a quick lesson in heat treating!
Always err on the safe side.
Not fun if the perch breaks or falls off - it can even be deadly!
