Ok... here is my own answers and comments to the survey:
1) Currently at 520RPMs. Why? Weber told me to set it at 400 to 500. I think this is too low and this is one reason I started the survey.
2) Exactly 2 turns in after contact. Again Weber said not to turn it in more that 2 turns or I am exposing my progression port. At 2 turns I get 520RPMs
3) 2.25 turns out. Weber said make sure between 1.5 and 2.5.
4) I had to jump up 2 idle jet sizes to the 85. Why? Back to Weber saying not to turn idle speed screw in more than 2 turns. With the stock idle jet and set at exactly 2 turns in on the idle speed screw then my idle was only 400RPMs. Way to low to me.
5) I set it to 1500 if engine is warm. When engine is cold it goes to about 1300 and slowly increases until I take choke off.
6) When I had the choke original set at 1800RPMS I could tap the pedal and it would drop to about 1300 and then tap again and it would drop to base idle. Now that I have choke set to 1500 I tap the pedal once and it drops to base idle.
7) My EGR is not connected at this time. I plan to connect it to the Weber EGR Port.
8)Vacuum advance is currently connected to Weber Port. Why? Just followed insturctions.
9)Currently using stock distributor with Accel coil. Changing over to HEI soon.
10) 5BDTC at 1600RPMs with no vacuum advance connected.
11) Automatic
12) No... however looking to do this based on a couple of other Jeepers recommendations.
13) Yes after a day or more it takes quite a few turn overs to fire up engine due to gas draining back. Haven't fixed it yet.
14) I am not sure due to tire size and speedometer being off, but my best calculation is about 13.5MPG
15) 33x12.5 Tires
Thanks again for your time.
11) Automatic
15) 33x12.5 Tires
