The Weber adapter is a 2-piece item.
The bottom piece bolts to the manifold (with recessed bolts)
The top piece bolts to the bottom piece, with reccesed bolts AND
have the correct holes for the carb.
Each piece is about 1/2" thick.
"Simply" machined from aluminium...
In the bottom piece, there is one (two ??) holes for vacum sources.
What else ?? you will need carb linkeage and modify the air filter housing.
Regards,
PerJ (From Norway)
[email protected]>
Using self-discipline, see
http://www.eiffel.com/discipline
