Water in Tranny, Damage from the Bash
745 views 6 replies 6 participants last post by  WILL
Today I finished the maintenance from the Bash weekend. The damage is:
The eye on the winch cable opened
The fender lips rolled down a little from tire contact at full lock, full compression
Water in the transmission
It's the latter that has me puzzled. I know that it didn't get in via the vent. The vent is downstream of the transfer case vent, which shipped no water. The other end of the vent hose is in the air cleaner. See the attached picture.
The only way I can think of that water could get in is through the shifter. I don't think it was submerged, but it certainly could have gotten some splashing around it.
Does anyone know of another way for water to get in?
Does anyone know of a way to seal the shifter of a T18?
Water gets everywhere when you are wheeling, could have come in through the shifter hole, maybe a loose fill plug i'm not real familar with the t18 but water likes to seep in every little seal. Also when your wheeling water will splash up and get into places you never think it will. Unless it was really puking out the fill hole you probably didn't get that much in it. I did fill a diff to the point once that about 4 quarts of grey goo was comming out, that's when you know it's really full of water.
#6 ·
Paul you have to be real careful with the autos they don't like water at all and will die quick, manuals are a little more durable. I'm not sure what year your jeep is and what year jeep went to the 4 speed auto in tj's but my old tj had the 3 speed auto(pretty much the same tranny used in 80+ cj's, yj's, and tj's). I filled it with water not once but twice and had it re-built twice and had the vent mod done after the second re-build.
The reason why the 3 speeds (i don't know how the 4 speed auto works and if this applies to them) suck in water is they have a pressure reliefe valve on the top of the trans and if you are in deep water or mud it can suck in water.
The only way to move the vent is to pull the trans and dissasemble it. Here's a write up http://www.ifsja.org/tech/transmission/727vent.shtml for a wagoneer trans but it's very similar and any trans guy should be able to make it work on a tj 3 speed trans.
We were going to have it done to our yj and i think the trans shop around here wanted 350 if we brought the jeep into them to have them do it and the re-build they did was either 650 or 750 so it's a whole lot cheeper to have it done before the day of death arrives. I wouldn't even think about having jeep do it and if you are still under warenty i'm not sure how this will effect it (you might even be able to get them to warenty a water filled trans if you were really nice and when they said no show them a jeep add where there's a jeep in water up to the bottom of the doors).
